Reply To: Securing glass panels – Beocenter 9300
#16750
Guy
    • Warwickshire, UK
    • Topics Started 14
    • Total Posts 1,235
    I have fixed the glass panels on two BC9500s using super glue gel, with no problems after approx 10 years.  Edit: I meant to add that I didn’t remove the old tape; just applied the gel over the top.
    And you can get the new belts etc from Beoparts. https://www.beoparts-shop.com/product-category/beocenter/beocenter-9300/
