BeoVision MX 7000
BeoVision MX 7000
The MX range was the first to bring the TV out into the open and it continues to show alternative ways of living with television. Beovision MX7000 was Bang & Olufsen’s first television set designed with active speakers. Beovision MX 7000 comes with the same Active loudspeakers technology that [...]
Beovision MX 7000 comes with the same Active loudspeakers technology that’s found in the BeoLab range of loudspeakers. By building the amplifiers directly into the speaker cabinet we’re able to ensure a sound performance that’s second to none. With the MX 7000 you have a full range of 6 colours and 5 placement options. Whether you prefer blue to red or a motorised stand to a non-motorised stand, the MX 7000 will give you a number of possibilities: 66cm screen with VisionClear, active loudspeakers, improved Teletext, Beo4 remote control, connections for Beolink®, VCR and headphones, optional module for satellite, BeoStands and motorised stands and available in pearlescent shades of: blue, green, red, grey, black or glossy white.
The Beovision MX series has become a classic. Designed by the famous David Lewis in the ’80s, this television set has gradually developed through the years to become the most known TV in the world today. Much has happened, however, since the first version. Today the MX7000 is equipped with the latest in picture and sound technology. This is the first, and probably only, TV with an built-in active speaker system. By using the same technology as used in all their stand alone active speakers, Bang & Olufsen have managed to provide sound quality that is hard to believe. The MX6000 is really the same machine as the MX7000 but without the active speakers. It features a passive system instead. When it comes to the picture, the current version features a 28 inch Backline S CRT along with the contrast screen and the other VisionClear components.
The MX series can, of course, be equipped with built in satellite receiver/Positioner and a Picture-In-Picture (PIP) module. For those wishing to use the Teletext subtitles when a program is using them the MX sets automatically turns them on and, in conjunction with a Beocord VX7000, it can also record a program with subtitles. All versions can be connected to the motor stands giving the possibility to adjust the viewing angle remotely. The MX7000 is available in the same colours as the Avant, namely pearly red, blue, black, green and grey.
With the MX range, the TV finally becomes a discreet part of your interior decoration. Choose between a 51cm or 66cm screen, 6 different colours and a versatile range of stands and brackets – with or without motorised turning. What comes as standard, however, is an uncompromising sound and picture quality that has set the reference for modern television.
Design
Filling a television with every conceivable gadget that technology offers is easy enough. What’s more difficult is identifying what really improves the overall experience of watching TV and eliminating the things that don’t. That’s the philosophy behind the MX range. In both form and function, it’s a clear-cut case of less being more. Beovision MX 7000 is controlled by the Beo4 remote control.
Beovision MX 7000
With the MX 7000 you have a full range of 6 colours and 5 placement options. Whether you prefer blue to red or a motorised stand to a non-motorised stand, the MX 7000 will give you a number of possibilities.
Bang & Olufsen have a long lasting commitment to the principle of Active Loudspeakers, i.e. the idea that each loudspeaker unit is powered by an individual amplifier with a specific crossover network, to ensure perfectly natural sound reproduction. The principle has definite advantages in the field of television sound.
Despite critical operating conditions, Beovision products succeed in providing sonic performances which surpass those of many hi-fi systems. The active loudspeakers in Beovision Avant, for instance, reproduce a sound quality equal to a pair of BeoLab 2500s.
And if your demands exceed those of the average viewer, the speakers’ modularity allows you to enhance the sound performance with any choice of loudspeakers in the BeoLab range.
In October 2002, Beovision MX7000 was replaced with Beovision MX8000.
Release Date: 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002
Designer: David Lewis
Colour / Finish: black or glossy white, Red, Blue, Grey, Green
Beolink: DataLink
Dimensions W x H x D
65 x 67.5 x 46.5 cm
Weight
40.3 kg
Terminal included
Beolink 1000
Picture tube
70 cm Black Line-s, Black Matrix
Visible picture
66 cm
Contrast screen
Grey glass
VisionClear
Auto picture adjustment
Auto cut-off
Wideband CTI
Dynamic luminance peaking
Cabinet finish
White
Black
Blue
Grey
Red
TV tuner range
VHF, S, Hyper, UHF
CTV system
Multistandard NTSC on AV
Teletext system
FastText, 6 languages, memory
TV programmes
59
Sound
Stereo, Active speakers
Sound pressure level
96 dB stereo
Stereo decoder/Bilingual
Depending on type
A2 + NICAM
Speaker system
Bass-reflex, two way
Power consumption/Minimum
Typical 90W / 3 W
Market specifications:
Market:
TV tuner
CTV system
3385 AUS
UHF
PAL I
3383 GB
UHF
PAL I
Other
VHF, S, Hyper, UHF
Multistandard NTSC AV
Connections:
AV Link
2 x 21-pin sockets
Super VHS
YC playback 4-pin socket
Audio AUX Link
7-pin socket
Power Link
2 x 8-pin sockets
Stereo headphones
Jack socket 3.5 mm
Motorized stand operation
4-pin socket
Link compatibility:
Datalink
65 x 67.5 x 46.5 cm
Weight
40.3 kg
Terminal included
Beo4
Picture tube
Visible picture
66 cm
Contrast screen
Grey glass
VisionClear
Auto cut-off
Wideband CTI
TV tuner range
VHF, S, Hyper, UHF
CTV system
Teletext system
TV programmes
59
Sound
96 dB stereo
A2 + NICAM
Speaker system
Typical 90W / 2 W
Connections:
AV Link
2 x 21-pin sockets
Super VHS
Audio AUX Link
7-pin socket
Power Link
2 x 8-pin sockets
Stereo headphones
Jack socket 3.5 mm
4-pin socket
Link compatibility:
Datalink
Beovision MX 7000 IT
65 x 67.5 x 46.5 cm
Weight
40.3 kg
Terminal included
Beo4
Picture tube
Visible picture
66 cm
Contrast screen
Grey glass
VisionClear
Auto cut-off
Wideband CTI
TV tuner range
VHF, S, Hyper, UHF
CTV system
Depending on type: B/G/D/K/L/L´/I/ PAL SECAM NTSC on AV
Teletext system
Improved Teletext, FastText, 6 languages, 4 memory page pr programme
TV programmes
59
Sound
96 dB stereo
Depending on type:
A2 + NICAM B/G/I optional
A2 + NICAM B/G/L optional
Speaker system
Typical 90W / 2 W
Connections:
AV Link
2 x 21-pin sockets
Super VHS
Audio AUX Link
7-pin socket
Power Link
2 x 8-pin sockets
Stereo headphones
Jack socket 3.5 mm
4-pin socket
Link compatibility:
Datalink
Beovision MX 7000 NT
65 x 67.5 x 46.5 cm
Weight
40.3 kg
Terminal included
Beo4
Picture tube
Visible picture
66 cm
Contrast screen
Grey glass
VisionClear
Auto cut-off
Wideband CTI
TV tuner range
45 – 865 MHz, VHF, S, Hyper, UHF
CTV system
According to type: B/G/D/K/L/L´/I/M PAL SECAM NTSC on AV
Teletext system
TV programmes
59
Sound
96 dB stereo
A2 + NICAM
Speaker system
Typical 95W / 2,4 W
Connections:
AV Link
2 x 21-pin sockets
Super VHS
Audio AUX Link
7-pin socket
Power Link
2 x 8-pin sockets
Stereo headphones
Jack socket 3.5 mm
4-pin socket
Link compatibility:
Data Link
Downloads & Manuals
Documents & Downloads
Document
Type No.
Required
Action
BeoVision MX 7000
Service ManualSilver Log in
BeoVision MX 7000
Technical InformationSilver Log in
