BeoVision MX 6000
BeoVision MX 6000
Beovision MX6000 delivers the same uncompromising picture quality as the MX 7000. The only difference is the loudspeaker system which has conventional amplification using built-in passive speakers. The MX television range was the first to bring the TV out into the open and it continues to show al [...]
The MX television range was the first to bring the TV out into the open and it continues to show alternative ways of living with television. With the current MX range, the TV finally becomes a discreet part of your interior decoration. Choose between a 51cm or 66cm screen, 6 different colours and a versatile range of stands and brackets – with or without motorised turning. What comes as standard however, is an uncompromising sound and picture quality that has set the reference for modern television.
The Beovision MX series has become a classic. Designed by David Lewis in the 1980s, this television set has gradually developed through the years to become the most well-known TV in the world today. Much has happened however, since the first version. Today the Beovision MX6000 is equipped with the latest in picture and sound technology. This is the first, and probably only, TV with an built-in active speaker system. By using the same technology as used in all their stand alone active speakers, Bang & Olufsen have managed to provide sound quality that is hard to believe. The MX6000 is really the same machine as the MX7000 but without the active speakers. It features a passive system instead.
When it comes to the picture, the current version features a 28 inch BlackLine S CRT along with the contrast screen and the other VisionClear components. The MX series can, of course, be equipped with built in satellite receiver/Positioner and a Picture-In-Picture (PIP) module. For those wishing to use the Teletext subtitles when a programme is using them the MX sets automatically turns them on and, in conjunction with a Beocord VX7000, it can also record a TV programme with subtitles. All versions can be connected to the motor stands giving the possibility to adjust the viewing angle remotely.
With two colours and five placement options to choose from, the MX 6000 will suit almost any purpose and room environment. The Beovision MX6000 is basically an MX7000, but with a conventional speaker system instead of active loudspeakers.
Design
Filling a television with every conceivable gadget that technology offers is easy enough. What’s more difficult is identifying what really improves the overall experience of watching TV and eliminating the things that don’t. That’s the philosophy behind the MX range. In both form and function, it’s a clear-cut case of less being more.
Features
With 2 colours and 5 placement options to choose from, the MX 6000 will suit almost any purpose. Optional brackets are available; Beovision MX6000 is available in glossy black and glossy white only. The TV is controlled by the provided Beo4 remote control. It is a 66cm TV with VisionClear; stereo loudspeakers; improved Teletext; Beo4 remote control; connections for Beolink® VCR and headphones; BeoStand and motorised stands are optional.
Type Number: 851, 3300, 3301, 3303, 3304, 3305, 3306, 3307, 3309, 3312, 3313, 3314, 3316, 3318, 3500, 3501, 3503, 3504, 3505, 3506, 3507, 3540, 3543, 3549, 3552, 3558, 7810, 7811, 7812, 7814, 7815, 7816, 7817, 7853, 7854, 7855, 7856, 7857, 7857, 7858, 7859, 7862, 7863, 7864, 7866, 7867, 7868, 7869, 8710, 8711, 8712, 8714, 8715, 8716
Release Date: 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002
Designer: David Lewis
Colour / Finish: Black, Red, Blue, Grey, White
Beolink: DataLink
CTV system
Picture tube (Visual picture)
70 cm (66 cm)
Picture tube system
Flat square, Hi-Bri, In-Line 110 degrees
Contrast screen
With metallised coating
Design
High format cabinet
Cabinet
White, black, red, grey, blue
Main features:
Operation
Beolink 1000, one-way
Beolink 5000, two-way
Beolink 7000, two-way
TV tuner range
46 – 855 MHz: VHF, S, Hyper, UHF channels
*(System I 470 – 855 MHz: UHF channels)
No. of TV programmes
59 (+5 for local rooms)
Satellite identification
Station naming/program list
Satellite
*Prepared for BeoSat LM
No. of satellite programmes
> 99
Signal/noise level
> 35 dB/1 Vpp and antenna signal > 1mV
Crosstalk between sources
> 45 dB / 5 MHz
Teletext
FLOF, 6 alphabet
Teletext memory
4 x 59 page nos.
Sound system
*Nicam + A2 stereo decoder + A2 dual languages
Speaker system
2 x Bass Reflex
Long-term max. output power
2 x 40 W / 8 ohms
Harmonic distortion
< 0.5% at 15 W
Intermodulation
< 1%
Signal-to-noise ratio
> 50 dB weighted 50 mV (NICAM > 70 dB)
Frequency range, audio
25 – 20,000 Hz +/- 1.5 dB
Power bandwidth
25 – 20,000 Hz
Channel separation
A” stereo >26 (NICAM > 50 dB)
Bass control
+/- 8 dB / 100 Hz
Treble control
+/- 8 dB /10,000 Hz
Crossover frequency
3200 Hz
Power supply
220 – 240 volts
Power consumption
100 (75 – 165) W
Power consumption stand-by
3 W
Dimensions W x H x D
65 x 67.5 x 46.5 cm
Weight
40.3 kg
AV1 & AV2
S-VHS
Power Link 1 & 2
Audio Aux Link
External speakers L & R
Headphone
B&O stand
Link compatibility: Datalink
Beovision MX 6000 MK II
65 x 67.5 x 46.5 cm
Weight
40.3 kg
Terminal included
Beolink 1000
Picture tube
70 cm Black Line-s, Black Matrix
Visible picture
66 cm
Contrast screen
Grey glass
VisionClear
Auto picture adjustment
Auto cut-off
Wideband CTI
Dynamic luminance peaking
Cabinet finish – White, Black, Blue, Grey, Red
TV tuner range
VHF, S, Hyper, UHF
CTV system
Multistandard NTSC on AV
Teletext system
FastText, 6 languages, memory
TV programmes
59
Sound
Stereo
2 x 40 W / 8 ohms
Stereo decoder/Bilingual
Depending on type
A2 + NICAM
Speaker system
Bass-reflex, two way
Power consumption/Minimum
Typical 90W / 3 W
Market specifications:
Market:
TV tuner
CTV system
3309 GB
UHF
PAL I
3302 HK
UHF
PAL I
Others
VHF, S, Hyper, UHF
Multistandard NTSC AV
Connections:
AV Link
2 x 21-pin sockets
Super VHS
YC playback 4-pin socket
Audio AUX Link
7-pin socket
Power Link
2 x 8-pin sockets
External speakers
2 x 2-pin sockets
Stereo headphones
Jack socket 3.5 mm
Motorized stand operation
4-pin socket
Beovision MX6000 IT
65 x 67.5 x 46.5 cm
Weight 40.3 kg
Terminal included Beo4
Picture tube
Visible picture
66 cm
Contrast screen
Grey glass
VisionClear
Auto cut-off
Wideband CTI
TV tuner range
VHF, S, Hyper, UHF
CTV system
Depending on type: B/G/D/K/L/L´/I PAL, SECAM, NTSC on AV
Teletext system
Improved Teletext, FastText, 6 languages, 4 memory page pr. programme
TV programmes
59
Sound
Stereo
2 x 40 W / 8 ohm
Depending on type:
A2 + NICAM B/G/I optional
A2 + NICAM B/G/L optional
Speaker system
Typical 90 W / 2 W
Connections:
AV Link
2 x 21-pin socket
Super VHS
Power Link
2 x 8-pin sockets
External speakers
2 x 2-pin sockets
Stereo headphones
Jack socket 3.5 mm
4-pin socket
Beovision MX6000 Beo4
Dimensions W x H x D – 65 x 67.5 x 46.5 cm
Weight – 40.3 kg
Terminal included – Beo4
Picture tube
70 cm – 28″ Black Line-s, Black Matrix
Visible picture – 66 cm – 26″
Contrast screen
Grey glass
VisionClear
Auto cut-off
Wideband CTI
TV tuner range
VHF, S, Hyper, UHF
CTV system
Multi-standard NTSC on AV
Teletext system
TV programmes – 59
Sound – Stereo
2 x 40 W / 8 ohm
A2 + NICAM
Speaker system – Bass-reflex, two way
Power consumption/Minimum – Typical 90 W / 2 W
Connections:
AV Link – 2 x 21-pin socket
Super VHS
Audio Aux Link – 7-pin socket
Power Link – 2 x 8-pin sockets
External speakers – 2 x 2-pin sockets
Stereo headphones – Jack socket 3.5 mm
Motorized stand operation – 4-pin socket
Beovision MX6000 NT
Weight – 40.3 kg
Picture tube
Contrast screen
Grey glass
VisionClear
Auto cut-off
Wideband CTI
TV tuner range
45 – 865 MHz,VHF, S, Hyper, UHF
CTV system
According to type:
B/G/D/K/L/L´/I/M PAL, SECAM, NTSC on AV
Teletext system
TV programmes – 59
Sound – Stereo
2 x 40 W / 8 ohm
A2 + NICAM
Speaker system
Power consumption/Minimum – Typical 94 W / 2 W
Connections:
AV Link
2 x 21-pin socket
Super VHS
Downloads & Manuals
Documents & Downloads
Document
Type No.
Required
Action
BeoVision MX 6000
Service ManualSilver Log in
BeoVision MX 6000
Technical InformationSilver Log in
