BeoVision LX 5000
BeoVision LX 5000
Beovision LX 5000 and LX6000 were the classic Bang & Olufsen televisions, with the loudspeakers on either side of the screen. They were equipped with 66cm and 63cm Black Line picture tubes and VisionClear which makes the picture sharper and the colours clearer. Automatic adjustment of the contrast and light strength continuously kept the picture […]
Beovision LX 5000 and LX6000 were the classic Bang & Olufsen televisions, with the loudspeakers on either side of the screen. They were equipped with 66cm and 63cm Black Line picture tubes and VisionClear which makes the picture sharper and the colours clearer. Automatic adjustment of the contrast and light strength continuously kept the picture optimal under different light conditions in the room.
The powerful loudspeakers were based on a two-way bass reflex loudspeaker system that delivered the high sound quality of more and more TV programmes and video tapes. Both TVs were equipped with A2 and NICAM stereo systems.
A BeoSat LM satellite receiver could be built in, allowing access to 99 TV or radio programmes via a parabolic aerial. A D2MAC decoder could also be built in. Bang & Olufsen made it possible for you to pre-program the recording of video programmes from the satellite. The satellite receiver and video recorder were operated by the same Beolink® remote control that operated the TV.
The same remote control also did the work if the Beovision LX6000 and LX5000 were coupled to a Bang & Olufsen music system. Other connection options were headphones, decoders, TV games and camcorder.
Type Number:4227, 4225, 4226, 4223, 4279, 4228, 4273, 4221, 4282, 4220, 4224, 4270, 3374, 3373, 3363, 3367, 3361, 3372, 3360, 3365, 3364, 3366, 3376
Release Date:1992, 1993, 1994, 1995
Designer:David Lewis
Beovision LX5000 Mk I Specifications
Picture tube (Visual picture): 63cm (59cm)
Picture tube system: flat square, Hi-Bri, In-Line 110 degrees
Contrast screen with metallised coating
Design: high format cabinet
Finish: Rosewood, white, grey metallic
Operation: Beolink 1000, one-way, Beolink 5000, two-way, Beolink 7000, two-way
TV tuner range: 46 – 855 MHz: VHF, S, Hyper, UHF channels
*(System I 470 – 855 MHz: UHF channels)
No. of TV programmes: 59 (+5 for local rooms)
Satellite identification: station naming/programme list
Satellite: *prepared for BeoSat LM
No. of satellite programmes: 99
Signal/noise level: > 35 dB/1 Vpp and antenna signal > 1mV
Crosstalk between sources: > 45 dB / 5 MHz
Teletext: FLOF, 6 alphabet; memory: 4 x 59 page nos
Sound system: *NICAM + A2 stereo decoder + A2 dual languages
Speaker system: 2 x bass reflex
Long-term max. output power: 2 x 40 W / 8 ohms
Harmonic distortion: < 0.5% at 15 W
Intermodulation: 50 dB weighted 50 mV (NICAM > 70 dB)
Frequency range, audio: 25 – 20,000 Hz +/- 1.5 dB
Power bandwidth: 25 – 20000 Hz
Channel separation A” stereo: >26 (NICAM > 50 dB)
Treble control: +/- 8 dB /10000 Hz
Crossover frequency: 2500 Hz
Power supply: 220 – 240 V
Power consumption: 100 (75 – 165) W
Power consumption stand-by: 3 W
Dimensions W x H x D: 78 x 47 x 42cm
Weight: 36.5 kg
Connections: AV1 & AV2, S-VHS, Power Link 1 & 2, Audio Aux Link, External speakers L & R, Headphone, B&O stand
Link compatibility: Datalink
Beovision LX5000 Mk II Specifications
Picture tube (Visual picture) 63cm (59cm)
Picture tube system Flat square, Black Line, Black matrix, In-Line 110 degrees
Cabinet Rosewood, White, Black, Blue, Grey
Crossover frequency 3200 Hz
Power supply: 230 volts
Power consumption: 95 (75 – 200) W
Power consumption stand-by: 3.5 W
Weight: 36.5 kg
No downloads available.
