BeoVision 7700
BeoVision 7700
Beovision 7700 was a 22″ colour TV with remote control of up to 16 stations. You could also adjust brightness, colour and sound levels – and switch the TV off – without moving from your chair. True high fidelity sound was a natural accompaniment to the excellent video performance of this set, thanks to a […]
True high fidelity sound was a natural accompaniment to the excellent video performance of this set, thanks to a 14 watts sound amplifier and log-line dual speaker system. There were also sockets for connecting optional headphones and an extension loudspeaker, and an additional connection for recording the TV sound on a cassette deck or feeding it through your hi-fi system.
Type Number:3313, 3323, 3330, 3363, 3373, 3333, 3314, 3374, 3414, 3407, 3334, 3344, 3353, 3413
Release Date:1980, 1981, 1982
Colour / Finish:Natural, Rosewood, Teak
CTV system IPAL
Picture size: 56cm nominal
Cabinet: wood
Number of programmes: 16 UHF channels 21 – 69
Picture tube: 110 degrees in-line self-converging
Start time: approx 5 seconds
Sound power output: 14 watts
Harmonic distortion: <0,3%
Frequency range +/- 1,5dB: 40 – 20000 Hz
Power supply (50 – 60Hz): 180 – 265 V
Power consumption: 65 – 130W
Consumption at normal use: 75W
Standby: <2W
Dimensions (WxHxD): 67,5 x 43,5 x 41,5cm/29Kg
Finishes: teak or rosewood
Standard features: Undercarriage (34cm high), headphones/ext speaker output, Channel indication, tape/amp output
Optional accessories: Loop amplifier, Teletext decoder, Video FBAS kit
No downloads available.
