Wiring Diagrams 2 :: Speaker Link / PowerLink
Speaker link cable from audio system or MCL to 4-pin wall plate using speaker plug number 7220040. Use unterminated link cable number 6250246 or 6250267:
green or brown signal hot
shield signal ground
white display data
shield data ground
PowerLink cable, male to male, using unterminated cable number 6250277 and plug number 7220345.  Maximum length 100m:
brown left audio signal
green right audio signal
shield: brown/green left/right ground
grey on/off
yellow on/off
pink APHC
white data
shield: white data ground
PowerLink cable, male to female (extension) using unterminated cable number 6250277, male 8-pin plug number 7220345 and female 8-pin plug number 7220235 or 8-pin DIN wall plate number 7210473.  Maximum length component to component: 100m:
brown
green
shield: brown/green
grey
yellow
pink
white
shield: white
PowerLink cable, female to female, using unterminated cable number 6250277 and two female 8-pin DIN plugs number 7220235 or two 8-pin DIN wall plates number 7210473:
brown
green
shield: brown/green
grey
yellow
pink
white
shield: white
PowerLink 1 & 2:
All wiring diagrams to plugs and sockets are shown from the soldering side.
Index
BeoTech © 2006 All rights reserved
