BeoSystem 9000C
The Beosystem 9000c is a beacon of beautiful sound, and your personal record store window. Paired with the Beolab 28 speakers, we’ve brought the Beosound 9000 CD player to the present. Only 200 of these exist We’ve stripped the original Beosound 9000 CD player to its core and rebuilt it from the ground up. Guided […]
We’ve stripped the original Beosound 9000 CD player to its core and rebuilt it from the ground up. Guided by design legend David Lewis’ original vision to proudly display your music, instead of hiding it in a black box. Its tall, transparent form makes a gallery of your albums. A duo of Beolab 28s showcase the unbeatable fidelity of your CDs. It’s a goosebump-raising partnership of acoustics and aesthetics. This is Beosystem 9000c.
All the benefits of cutting-edge tech. All the beauty of classic design.
Beosound 9000c is an icon of the past. With an ear to the future. A new anodised floor stand and fabric cable add texture to the famous silhouette. Want to truly bring past into present? The integration of Beoconnect Encore enables the player to connect seamlessly with two Beolab 28s – and all their modern features. Sound you can direct as you choose. Bass that adapts to any room and placement. Precise stereo coordination. In an age where CDs are considered obsolete, Bang & Olufsen celebrates the legacy of the CD with the Beosound 9000c. As champions of fidelity, we meticulously recreated this iconic CD player to give you every note, detail and beat of your collection. Like you’ve never heard it before. It’s not just about the superior sound. It’s feeling the music in your hands. Lingering on the artwork. Carefully choosing your lineup. With a 90s style control panel and six-CD changer to play with, Beosystem 9000c brings that back in the biggest way possible. Every listening session becomes an event. Each time you press play, you touch the music and it touches you.
The engineering of Beosystem 9000c isn’t just for show. It is the show.
The CD clamp accelerates as quickly as a sports car. An LED ring shines as it takes your discs for a spin. And with that speed comes seamless switching between individual album tracks – no matter which CD they’re on. It’s a single, endless stream of sound. 31 years before digital got there. All housed under a glass case to keep the artwork and movement as crystal clear as the music.
Imagined in London. Born in Denmark.
Soho, London, 1995. Bang & Olufsen designer David Lewis walks past a record store window and stops in his tracks. He sees six CDs, laid out in a row. A gallery of album art. It gets his mind turning: imagine you could put your music on display, instead of hiding it away in a black box. The idea for the Beosound 9000 was born. A six-CD changer and record store window in one. Designed so that everyone can bring a CD to the mix. And fill the home with an endless stream of beautiful sound.
Number of CDs
6 CDs
Recommended Room Size
15-50 m²
150-500 ft²
Speaker Configuration
Per Speaker:
1 x 1″ tweeter
3 x 3″ full range
1 x 6.½” woofer
Amplifier
Per Speaker:
1 x 100 watt, Class D, tweeter
3 x 100 watt, Class D, full range
1 x 225 watt, Class D, woofer
Total: 625 W
Frequency Range
27 – 23.000 Hz
Maximum Sound Pressure Level @1m
Per Pair: 110 dB (SPL)
Bass Capability
Per Pair: 95 dB (SPL)
Advanced Sound Features
Active Room Compensation
Adaptive Bass Linearization
Beam Width Control
Thermal Protection
Customizable Sound EQ
Presets available and fully customisable through the Bang & Olufsen App
Materials
Beosound 9000c:
Aluminium
Polymer
Glass
Beolab 28:
Aluminium
Fabric
Polymer
Dimensions (Width x Height x Depth)
Beosound 9000c with Floor Stand: 38.2 W x 137 H x 38.2 D cm
Per speaker with Floor Stand: 25.3 W x 137 H x 25.3 D cm
Weight
Beosound 9000c: 24.6 kg
Per Speaker: 18.6 Kg
Power Consumption
Beosound 9000c:
Typical: 12 W
Standby: < 1.2 W
Beolab 28:
Typical: 30 W
Network standby: 4.5 W
Standby: 0.5 W
Power Supply
Beosound 9000c: 100-240V 50/60Hz mains cable
Beolab 28: 100-240V 50/60Hz mains cable
Bluetooth Version
Bluetooth 5.0
Bluetooth Codecs
Android: SBC
iOS: SBC, AAC
Wi-Fi
Beolab 28:
Dual-Band Wi-Fi (2.4 & 5 GHz)
IEEE 802.11 b/g/a/n/ac
Streaming Services
Beolab 28:
Apple AirPlay
Spotify Connect
Google Cast
TIDAL Connect
B&O Radio
Deezer
QPlay 2.0
Beolink Multiroom
Yes
Wireless Powerlink / WiSA
Yes (up to 24 bit / 96 kHz)
Physical Connections
Beosound 9000c:
1 x AM aerial
1 x FM aerail
1 x Masterlink
1 x Powerlink (DIN)
1 x Digital output (SPDIF)
1 x AUX socket (DIN)
1 x AC power
Per Beolab 28 speaker:
2 x Ethernet
1 x Power Link (RJ45)
1 x Line-in/Optical combi-jack
1 x USB-C (Service)
1 x USB-A (Service)
1 x Power
Remote Control
Bang & Olufsen App
Beoremote One BT
Beoremote Halo
On-Device Controls
Yes
| Title | Categories | View |
Photo Gallery
Warning: Trying to access array offset on false in /var/www/vhosts/beoworld.org/httpdocs/wp-content/themes/storefront-child/post-template-beoworld-product.php on line 211
Deprecated: ltrim(): Passing null to parameter #1 ($string) of type string is deprecated in /var/www/vhosts/beoworld.org/httpdocs/wp-includes/formatting.php on line 4486
Warning: Trying to access array offset on false in /var/www/vhosts/beoworld.org/httpdocs/wp-content/themes/storefront-child/post-template-beoworld-product.php on line 212
