BeoSound Emerge
BeoSound Emerge
A slim bookshelf speaker that fits in anywhere and reaches you everywhere in the room with full-range, ultra-wide sound. Surprisingly big sound Expand your music experience without compromising on space. Revolutionary driver configuration The ultra-slim profile contains a revolutionary driver configuration finely tuned by Bang & Olufsen engineers. Ultra-slim to fit any space An ultra-slim […]
An ultra-slim profile with a book-inspired design and a footprint of only 6.7cm, Beosound Emerge is an elegant and versatile addition to every room – whether in a prominent position or discreetly tucked away on a shelf.
Tactile materials of the finest quality
Crafted using premium materials, such as precision cut, pearl-blasted aluminium, natural oak and woven textile from Kvadrat. Each element is chosen for its performance properties, aesthetics and special textural qualities. Beosound Emerge is the manifestation of the perfect balance between elegance and natural beauty.
Elegant user interface
Intuitively integrated into the top of the speaker, the interface is designed to be easily accessed in a variety of spaces. Use the soft-touch buttons to seamlessly access your favourite Bang & Olufsen radio stations, search on Google or stream via Spotify and adjust volume with a unique circling motion, a pleasurable experience in itself.
Recommended Room Size
5-30 m²
50-300 ft²
Speaker Configuration
1 x 0.6” tweeter
1 x 1.45” mid range drivers
1 x 4” woofer drivers
Amplifier
1 × 30 W class D for tweeter
1 × 30 W class D for mid-range
1 × 60 W class D for woofer
Total: 120 W
Frequency Range
45 – 22.000 Hz
Maximum Sound Pressure Level (SPL) @1m
92 dB SPL
Bass Capability
72 dB SPL
Stereo Pairing
Pair two Beosound Emerge to enjoy a stereo listening experience.
Advanced Sound Features
Active Room Compensation
Adaptive Bass Linearization
Thermal Protection
Customizable Sound EQ
Presets available and fully customisable through the Bang & Olufsen App
Materials
Oak Wood
Fabric
Aluminium
Polymer
Dimensions (Width x Height x Depth) (cm)
6.7 W x 25.5 H X 16.5 D cm
Weight
1.3 kg
Power consumption
Typical 15 W
Standby: 4.5 W
Power Supply
USB-C Power Supply
USB-C Cable
Bluetooth Version
Bluetooth 5.0
Bluetooth Codecs
Android: SBC
iOS: SBC, AAC
Wi-Fi
Dual-Band Wi-Fi (2.4 & 5 GHz)
IEEE 802.11 b/g/a/n/ac
Streaming services
Apple AirPlay
Spotify Connect
Google Cast
TIDAL Connect
B&O Radio
Deezer
QPlay 2.0
Beolink Multiroom
Yes
Physical Connections
1 x Ethernet
1 x Line-in/ Optical combi-jack
1 x USB-C (Power)
Remote controls
Bang & Olufsen App
Beoremote One BT
Beoremote Halo
On-Device Controls
Yes
Language
User Guide
EN
Beosound Emerge User Guide
Data Sheet
EN
Beosound Emerge Data Sheet
