BeoSound A1
Longer playtime, integrated voice assistant, and speakerphone. Meet the upgraded waterproof bluetooth speaker tailored for great sound on the go. Partner in sound. From the pool to the penthouse. Grab it and go. Or hang it on the wall. Beosound A1 has been specifically crafted to move with you and fit in just about anywhere. […]
Grab it and go. Or hang it on the wall. Beosound A1 has been specifically crafted to move with you and fit in just about anywhere. From cooking in the kitchen to cooking in the sun, the fully dust and waterproof IP67 construction means you don’t have to worry about any of life’s thrills or spills.
Recommended Room Size
5-30 m²
50-300 ft² room
Speaker Configuration
1 x 0.6″ tweeter
1 x 3 ½” woofer
Amplifier
1 x 30 W class D for tweeter
1 x 30 W class D for woofer
Total: 60 W
Frequency Range
55-20.000 Hz
Maximum Sound Pressure Level (SPL) @1m
92 dB SPL
Bass Capability
62 dB SPL
Stereo Pairing
Yes (Available between two Beosound A1 2nd Gens)
Customizable Sound EQ
Presets available and fully customisable through the Bang & Olufsen App
Materials
Pearl Blasted Anodized Aluminium
Waterproof Leather
Polymer
Dust and Waterproof Rating
IP67
Dimensions (Width x Height x Depth) (cm)
13.3 W x 4.6 H x 13.3 D cm
Weight (g)
558 g
Battery Playtime
Up to 18 hours
Charging Time
Approximately 2.75 hours
Bluetooth Version
Bluetooth 5.1
Bluetooth Codecs
aptX Adaptive
AAC
Physical Connections
1 x USB-C (Charging)
On-Device Controls
Yes
Speakerphone
Yes
Multipoint
Yes (Up To 2 Devices)
Certifications / Fast Pairing
Made for iPhone (MFI)
Google Fast Pair
Microsoft Swift Pair
Type | Language | Type | |
Quick Start Guide | EN | Beosound A1 2nd Gen Quick Start Guide | |
User Guide | EN | Beosound A1 2nd Gen User Guide | |
Data Sheet | EN | Beosound A1 2nd Gen Data Sheet |
Photo Gallery
No gallery images.
