BeoLab 20
The crowning glory of Beolab 20 is the Acoustic Lens that delivers smooth high-frequency sound in full 180 degrees. The results are uncompromising listening experiences across your room and much greater freedom in terms of where you place your speaker for optimal sound. SOUND Hear it and believe it. Very few speakers can rival the […]
SOUND
Very few speakers can rival the formidable combination of power and poise of the Beolab 20. At the heart of its refined acoustic performance is a custom-built digital sound engine, that’s refined to optimise every single component inside this wireless speaker.
DESIGN
Sophisticated from the inside out
Beolab 20 is a truly powerful speaker, designed with an elegant and surprisingly compact appearance. With the body almost entirely draped in your choice of high-quality fabric, this stylish speaker easily adapts to its surroundings.
ADAPTIVE BASS
Creating the perfect lows
To deliver precise and intensive bass without the risk of damaging your speaker at high volumes, our Adaptive Bass Linearisation technology constantly monitors and adapts the speaker’s bass performance.
ROOM ADAPTATION
Superior sound from any position
Every speaker will sound different depending on its position in a room. Beolab 20 features our innovative room adaptation technology that optimises the audio performance based on your speaker’s actual placement in a corner, against a wall or free-standing.
Frequency Range
19,5 – 23,600 Hz
Maximum Sound Pressure Level @1m
108 dB SPL
Bass Capability
104 dB SPL
Advanced Sound Features
Acoustic Lens Technology
Adaptive Bass Linearization (ABL)
Acoustic Placement Settings
Thermal Protection
Drivers
1 x 3/4″ tweeter
1 x 5″ midrange
1 x 10″ woofer
Amplifiers
1 x 160 watt, Class D, tweeter
1 x 160 watt, Class D, midrange
2 x 160 watt, Class D, woofer
Connections
2 x Power Link (RJ45)
1 x RCA (L/R)
Wireless Power Link (24 bit / 48 kHz)
WiSA (24 bit / 96 kHz)
Wi-Fi
1 x TOSLINK
– in: Sample rate 32k, 44.1k, 48k, 96k/PCM16-24 bit
– out: Sample rate 48k/PCM 24 bit
Weight
18kg
Dimensions
39.3 W x 82 H x 30.4 D cm
Type | Language | Type | |
Data Sheet | EN | BeoLab 20 Data Sheet | |
Service Manual | EN | BeoLab 20 Service Manaul |
Photo Gallery
No gallery images.
