No image available
BeoCord VCR61
A development of the VCR60, changing due to changes in the donor Grundig machine. Not sold in the UK.
Type Number: 4455
Release Date: 1984, 1985, 1986
Mains voltage 220 – 240 V +/- 10%
Frequency 48 – 62 Hz
Power consumption in ON 45 W
Power consumption in STANDBY 10 W
Ambient temperature + 10 to +35° C
Relative humidity 30 – 80 %
Maximum playing time
2 x 4 hours with VCC 480
Wind/rewind time < 160 sec. with VCC 480
Dimensions: W x D x H 43.8 x 27.4 x 11.7 cm / Weight 8 kg
Position of normal end use Horizontal: max. 15°
Number of programmes 35 + AV
Number of pre-programmable blocks 5
Maximum period for pre-programming 0 – 30 days or every day
Video:
Signal-to-noise ratio > 47 dB (CCIR 421 – 2 annex III)
Resolving power > 3.1 MHz (- 26 dB)
Signal drop-out consumption Max. 5 lines
Audio:
Frequency response 40 – 10,000 Hz +/- 8 dB
Wow and flutter < 0.3 % (DIN45507)
Distortion < 6 %
Signal-to-noise ratio > 50 dB (DIN45500)
Tuner:
Band I 45 – 85 MHz (Channels 2 – 4)
S-channels 105 – 168 MHZ (Channels S1 – S10)
Band III 163 – 224 MHz (Channels 5 – 12)
S-channels 231 – 287 MHz (Channels S11 – S19)
Band IV/V 471 – 855 MHz (Channels 21 – 69)
Modulator:
Adjustable modulation Channel 30 – 40 (543 – 623 MHz
Output voltage 3 mV (RMS) +/- 3 dB
Connections: Audio in/out
21-pin AV
Downloads & Manuals
