BeoCord V8000
BeoCord V8000 video tape recorder matched the Beovision MX range of Bang & Olufsen televisions in looks as well as performance. You could store a channel on the Beovision MX TV and it was automatically communicated to the V8000. Recording was a simple matter of selecting the programme directly from Teletext using the Beo4 remote control. It could be […]
You could store a channel on the Beovision MX TV and it was automatically communicated to the V8000. Recording was a simple matter of selecting the programme directly from Teletext using the Beo4 remote control. It could be positioned by using one of the stands as part of a Beovision TV.
BeoCord V8000 rewound a three-hour tape in 95 seconds and it shifted from fast forward to play in a split second.
Other features included NTSC stereo playback. Looks-wise it embodied a black fascia with a choice of cabinets in pearlescent shades of blue, green, red, grey and black, plus glossy grey and glossy white.
Dimensions W x H x D / Weight:
38 x 10 x 28 cm / 4.3 kg
Cabinet finish:
White, black, silver, red, green, blue
Remote control: Beo4, Beo1
Tuner range: VHF, S, Hyper, UHF
CTV system: According to type: B/G/L/L/I/D/K PAL, SECAM*
TV programmes: 99
Stereo decoder: According to type: NICAM + A2, NICAM
Improved picture quality: Automatic optimised for own and rental tapes
Recording system:
HQ
PAL
Type 4605: PAL, SECAM, ME
SECAM to PAL transcoded recordings Slow motion: 1/2,1/12 x normal speed
Still picture: Noiseless
Tape counter: Time left, time used
Track marker: Set and erase
Timer programming: 8, 1 year
Sound system: Hi-Fi stereo
Video playing time, E-240: SP 4 hours, LP 8 hours (NTSC: SP, EP, LP)
Audio playing time, E-240: LP 8 hours
Connections:
AV: AV Link 21-pin socket
Camcorder IN: 3 phono sockets
V-Tape decoder: AV 21-pin socket
RF input socket: 75 ohms
RF output socket: 75 ohms
Cassette system: VHS
Quickloading: Yes
Subtitles from Teletext: Yes, in colours
On screen display: Yes
Playback of tapes recorded in:
NTSC 3.58 and NTSC 4.43 in Hi-Fi stereo sound
S-VHS (VHS quality)
Disc sizes: 12 cm - 8 cm
Frequency range: 20Hz - 20KHz
Playback the and rewind: Approx. 95 sec. E-180
Search forward/backward: PAL, SECAM: 5 x and 11 x normal speed,
Signal-to-noise-ratio SP mode:
Luminance >= 48 dB
Chrominance >= 38 dB (AM)
Chrominance >= 31 dB (PM)
Sound, compatible Hi-Fi/normal:
Stereo Hi-Fi/mono fixed head
Tape heads: 2 LP video, 2 SP video, 2 Hi-Fi sound
Sound frequency range: 20 - 20,000 Hz, 1 3 dB
Hi-Fi distortion: 63 dB
Modulator tuning range: 471 - 855 MHz, System I
Power supply: 180 - 240 volts/50 Hz
Power consumption: Typical 22 watts / standby< 2.1 watts
Type | Language | Type | |
User Guide | DK | BeoCord V8000 MS User Guide | |
User Guide | EN | BeoCord V8000 MS User Guide | |
User Guide | FIN | BeoCord V8000 MS User Guide | |
User Guide | DE | BeoCord V8000 MS User Guide | |
User Guide | NL | BeoCord V8000 MS User Guide | |
User Guide | DK | BeoCord V8000 MX User Guide | |
User Guide | EN | BeoCord V8000 MX User Guide | |
User Guide | FIN | BeoCord V8000 MX User Guide | |
User Guide | DE | BeoCord V8000 MX User Guide | |
User Guide | NL | BeoCord V8000 MX User Guide | |
Exploded View | EN | BeoCord V8000 Exploded View |
Photo Gallery
No gallery images.
